Could use some help adding an angle part
StillMakerStillMaker Member Posts: 26 EDU
edited October 2024 in Using Onshape
I'm trying to build a stand that screws into the VESA mounting holes on the back of a monitor, and holds a light-therapy lamp on top of the monitor. It's basically a shelf with a specific angle to point my lamp down at me.
I'm struggling with the top shelf part, when I extrude it it becomes a new part, instead of adding onto the existing part. I'm probably doing something wrong with the line angle plane. Maybe I should be using a different technique?
Thanks for any help.
https://cad.onshape.com/documents/62aabd725ec811c446d74e72/w/2348c4c1bd771052e5c0a140/e/99935826f238d218fccd9253?renderMode=0&uiState=6715789e0eb57b2e67bceab8
