Feature Request: Frames Cut List Improvements
I've been using Onshape's Frame feature for woodworking and it's been incredibly helpful. However, I have run into some situations where some additions to the Cut List would be really useful for me.
  • Ability to change length unit
  • Ability to reorder Items
  • Title Column
  • Notes column or other open text field
  • Material column
  • Stock Column - So you can choose a stock length that the cut will be made from
  • It seems in general, a lot of the fields available in BOM would be helpful in the Cutlist (or the other way around).
I know I could export as a csv and make these changes/additions elsewhere, but would love to be able to do it all within Onshape.
Thanks!
  • CarlGutierrezCarlGutierrez Member Posts: 9 PRO
    I'd like to request that there be an option to show cut list lengths in fractional units and be able to round to the nearest 16th.
  • MichaelPascoeMichaelPascoe Member Posts: 2,817 PRO
    edited October 2024
    This is possible with FeatureScript. @Chris_von_Staats feel free to reach out and DM me if you need a custom feature built for this.
    @Carl_ICE Do you want rounding added to the ICE CutList feature? 😎
    RENDERCAD
  • andy_colbornandy_colborn Member Posts: 13 PRO
    I was working on modular homes, and we ended up using this community featurescript (Pretty Cut List), which is a fork of the native Onshape Frame tool:
    https://cad.onshape.com/documents/225647a2d97a22ec808fe461/w/a17046fd92486848101b2349/e/b84a2f38ce973afcc949e2a8
    We then made a number of small modifications to it ourselves to allow us to write properties to each stick of lumber (Doug Fir, length (fractional and decimal inches, etc).
    I do think the frame tool could use some improvement, but as Michael Pascoe mentioned, it's all doable with some featurescript.
