Loft 2 surfaces with inner loops
microsoft_ppmicrosoft_pp Member Posts: 6
I am trying to loft 2 surfaces together to create a solid with a tapered hole, but I get the error "Cannot use faces or regions with inner loops as profiles." I'm still fairly new at this, and help would be appreciated.
https://cad.onshape.com/documents/3bae974cb63095d1ec905a5c/w/dfc08c39a2df85ec40cc3610/e/8049ba5aba3313f53a8ec729?renderMode=0&uiState=671732b0e360df48201a6362
  • MDesignMDesign Member Posts: 1,026 ✭✭✭✭
    edited October 2024
    Doesn't seem like I can open your link. But you will probably have to do the hole as a separate feature
  • rick_randallrick_randall Member Posts: 402 ✭✭✭
    You can only loft single profile regions - for example, you can not loft a sketch that contains a circle profile inside a rectangle profile. You could edit the circle profile into construction geometry - that way you meet the requirements of a single profile sketch (the rectangle), and then, later you can project the construction geometry to a new sketch for use as a loft profile. I would recommend the "shell" command if your design calls for constant thickness - otherwise a 2nd loft to cut the inner contour is required .
  • glen_dewsburyglen_dewsbury Member Posts: 1,134 PRO
    Not sure what the surface fills are about. The solid loft works fine when you add the holes after.
    https://cad.onshape.com/documents/c735f911656197548a135a03/w/f0b97f029af9835d24cd6326/e/3a85931eab7ae18560ef7da1
  • microsoft_ppmicrosoft_pp Member Posts: 6
    Solved, Thank you.
    I don't want the body to be tapered, just the internal hole, which I managed to do, but thank you.
    oop, this should work
