Setting UIHint parameters from feature edit function
graham_lockgraham_lock Member Posts: 256 PRO
edited October 2024 in FeatureScript
Hi,
Is there a way to apply UIHints from code - for example make a field read only within the feature edit function if certain other criterion are met?
Thank you.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 346 PRO
    No, you cannot set UIHints dynamically.
    But…there is a work around with editing logic.
    Make two identical fields, one that is read only another that is not read only.
    Make another field that has UIHint.Always_hidden, is a boolean, and controls the visibility of the other two fields.
    When the read-only condition is met, set that field with editing logic so that the editable field is hidden and the read only is visible.
    Example:
    https://cad.onshape.com/documents/8477b927bcadbb9f95b06c09/w/7544e4a05c45a8f6578681b0/e/852cedb2769a0877d1e4dafe
    export function EditingLogicFunction(context is Context, id is Id, olddefinition is map, definition is map, isEditing is boolean) returns map
    // condition for visibility
    definition.isVisible = definition.myLengthControl > 50*millimeter;
    // Update the value
    definition.myLengthReadOnly = definition.myLength;
    return definition;
    annotation { "Feature Type Name" : "My Feature", "Feature Type Description" : "", "Editing Logic Function":"EditingLogicFunction" }
    export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Controls other field readonly" }
        isLength(definition.myLengthControl, LENGTH_BOUNDS);
        annotation { "Name" : "control Visiblity", "UIHint" : UIHint.ALWAYS_HIDDEN }
        definition.isVisible is boolean;
        if (definition.isVisible)
            annotation { "Name" : "My field" }
            isLength(definition.myLength, LENGTH_BOUNDS);
        if (!definition.isVisible)
            annotation { "Name" : "My field", "UIHint" : UIHint.READ_ONLY }
            isLength(definition.myLengthReadOnly, LENGTH_BOUNDS);
        // Define the function's action
    www.smartbenchsoftware.com --- fs.place --- Renaissance
    Example:
    // Update the value
    return definition;
    precondition
  • graham_lockgraham_lock Member Posts: 256 PRO
    Thank you for answering and taking the time to generate an example, much appreciated.
