What is the proper approach in onshape for splitting model into multiple parts? (reverse assembling)
dominik_panasdominik_panas Member Posts: 17
edited October 2024 in Drawings
Ive started designing a month ago and already faced this problem twice, this is 3rd time. I design something, test it, design again and at some point im like "ok i should probably split this into two/multiple parts".
For example currently i have this model
https://cad.onshape.com/documents/089bf14321e096ed62971769/w/ba9a1bb16af4c75e23d77516/e/3f172d06fe674ef77ff452fe
At some point i decided to split it into 2 parts - (elastic) "ball" part and its base with a hole and (hard) the "disk" part in which i will just push the elastic part in. Here is where i want to make a joint (red lines)
So what is the approach in such situations? Before i re-created my parts from scratch but this is painful
  1. Remove disk and try to recreate it? I already use some variables but the point of joint highly depend on balls curve so it cant be measured upfront.
  2. Copy/paste the model on the side and remove disk from ball model and ball part from disk model? I would also have to copy/paste sketch too.
  3. Duplicate whole document, do things from point2 and then import the disk from separate document?
  4. Add those "cut" lines in sketch and make 2 separate extrude/revolve as NEW features?
    edited October 2024
    Usually you would just start off using two separate revolves.
    In the case where you forgot and it would be a huge pain, you can revolve those red lines as a surface, then use the Split feature and split the part with the surface. Note that the split feature requires the surface to completely pass through the part, it can't be mostly to the edge of the part.
    RENDERCAD
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 389 image
    As Michael suggests, you should leverage multi-part part modeling - it works really well in Onshape!
  • joshtargojoshtargo Member Posts: 495 EDU
    edited October 2024
    Select NEW instead of ADD when you do a revolve or extrude that should be a separate part. Additionally, the fact that the feature timeline allows you to go back in time, you can use this to change features in the past as your design evolves.
  • dominik_panasdominik_panas Member Posts: 17
    Thanks! I already fixed the problem as you said - by adding those 2 lines to the sketch and then use NEW when extruding the disk. I also exported them as 2 separate models.
    Thanks!
