Optional function parameters
Hi. Newbie here.
Does FeatureScript support optional function parameters?
If not I see two options:
Function overloads
function decrement(n is number) returns number { return decrement(n, 1); } function decrement(n is number, amount is number) returns number { return n - amount; }
Passing undefined
as optional parameter value
Should be possible but then how do I write a precondition if parameter is not undefined it should be of certain type.
Thanks
NeilCooke Moderator, Onshape Employees Posts: 5,859
Overloads is the easiest way
Senior Director, Technical Services, EMEA0 -
Caden_Armstrong Member Posts: 271 PRO
The other option is to pass in a map of all parameters, but I agree with Neil that overloads is the best option.
www.smartbenchsoftware.com --- fs.place --- Renaissance
Custom FeatureScript and Onshape Integrated Applications0
