Optional function parameters
ramunas_k
Member Posts: 2 ✭
Hi. Newbie here.
Does FeatureScript support optional function parameters?
If not I see two options:
Function overloads
function decrement(n is number) returns number
return decrement(n, 1);
function decrement(n is number, amount is number) returns number
return n - amount;
Passing undefined as optional parameter value
Should be possible but then how do I write a precondition if parameter is not undefined it should be of certain type.
Thanks
NeilCooke
Moderator, Onshape Employees Posts: 5,979
Overloads is the easiest way
Senior Director, Technical Services, EMEA0 -
Caden_Armstrong
Member Posts: 400 PRO
The other option is to pass in a map of all parameters, but I agree with Neil that overloads is the best option.
www.smartbenchsoftware.com --- Renaissance --- fs.place
Experts in Onshape Automation - Custom Features and Integrated Applications0
