How can I remove a certain chunk of a rectangle with a triangular face as it is on 3 different faces
When I try to extrude this shape it doesn't allow me any help on this?
  • MDesignMDesign Member Posts: 1,186 PRO
    one way to do this would be a removal loft of any of the triangles to the opposing vertex. Another if using extrude and you have the edge lines already there like shown in pic is…just use any of the triangles and set the direction checkbox and then pick one of the lines on one of the faces.
  • EvanReeseEvanReese Member, Mentor Posts: 2,619 PRO
    Here's what comes to mind for me.
    • Sketch 1 just has 2 points
    • plane 1 is a 3 point plane using the corner of the box and the sketch points
    • The plane is used to split the part and remove that corner
    • https://cad.onshape.com/documents/f276d7d658f3ca3408ea3e7b/w/d0c253beeb551aaf9cedb99f/e/aeacbaf5bedfb69617022eca
  • eric_pestyeric_pesty Member Posts: 2,413 PRO
    You could also use a loft from a sketched triangle on the nearest face to the point.
