opFitSpline simply not working, randomly, even with valid points
joshtargojoshtargo Member Posts: 495 EDU
script is here:
https://cad.onshape.com/documents/cc4e811a68209246c3d6a244/w/99faf8c3a688d2acb43db83e/e/ed415a3e3f1f9618ed93d8dc?renderMode=0&uiState=6723d388b042933aa7f9bd0b
  • joshtargojoshtargo Member Posts: 495 EDU
    @S1mon yeah, I tested with DrawFS and it fails if there is a loop. crazy. I added an exception and error message in my radius FS, which is getting pretty good now.
  • S1monS1mon Member Posts: 4,091 PRO
    Perhaps create the hairs, and try using the regular 3DFitSpline feature manually to see if you get better feedback?
    Some guesses would be that the resulting curve has a cusp, a loop (where it would intersect) or a couple input points which are too close together.
