Watermark in drawing template always in front of drawing views
Member Posts: 33 PRO
Hello there!
When creating a drawing template with a watermark, the watermark picture is always placed in front of all drawing views.
Even if I send the picture to the back and move it to the border in the template, as soon as I use the template in my drawings, it gets sent to the front. I have to unlock the border manually, send the picture to the back an lock it again directly in every drawing. As soon as I update the drawing, the picture gets send to the front again. I would consider this a bug, since there is no case where the current behaviour makes sense.
Does anyone else have this problem?
Thanks!
  • Member Posts: 4
    Hi, we have the same problem, we tried all possible workaround without any success. We opened a support ticket, if we get any good solution we will share the info with you.
  • Member Posts: 4
    Hi, we had the smae problem, we asked support and they told us they will let us know when fixed
  • Member Posts: 33 PRO
    Hi, thank you for your update! Same here. The behavior has improved but is not completely gone. When I update the drawing, the image stays in the back. But when I create a new drawing with the template and drop my first view into the drawing, the same problem occurs. Please fix this onshape, I have to create many drawings with a watermark, and this is getting cumbersome.
  • Member Posts: 137 PRO
    Same issue. Can't have any watermarks. This seems like such a basic function :-(
