Retrieve documenthistory with API
felix_hahnlein
Member Posts: 4 EDU
Hi, I would like to retrieve the entire documenthistory (all microversions) from a given document.
Currently, I'm using the documents/documenthistory endpoint (https://cad.onshape.com/glassworks/explorer/#/Document/getDocumentHistory), but it seems only to return a fixed number of microversions from the history. To retrieve the entire history, I'm looping this API call until I got everything. But this makes for a lot of calls and I don't want to overload the servers.
Is there a parameter to increase the number of microversions or to retrieve the entire history?
Alex_Kempen
Member Posts: 255 EDU
There doesn't appear to be a way to increase the amount of micro versions returned by the documenthistory endpoint. What are you trying to do?
FRC Design Mentor - Team 1306 BadgerBots0
Is there no way of getting the entire document history? In glassworks, it's returning 130+ but when I run it in python, I'm only getting 50
Make sure you're using the latest version of the API (currently v9) - Onshape may have tweaked the behavior.
