How do I cut this part?
roger_andre
Member Posts: 4 ✭
Hi,
I need to cut this part in half at the place indicated with red circles.
I can't seem to create a plane or a surface in the right spot to do so and would appreciate some suggestions.
Project is public and at
Thanks!
MDesign
Member Posts: 1,258 PRO
Extend the two lines in the sketch beyond the part surfaces. Extrude just those two lines into a surface that passes completely through the part on both sides and use the slice feature to split it in half.
2
Depends what you mean by 'cut'
Not sure where you want the cut but have a look at this to see if it helps
https://cad.onshape.com/documents/64ad939057da792d4a47d07c/w/fc9e39e4ee47b32aa0a49920/e/fc30745d17afb39c87c826ef
Hello Roger. Perhaps this. - Scotty
Thank you MDesign. As usual, it's easy once you know how to do it. Worked great.
