making use of "throw" information
EvanReeseEvanReese Member, Mentor Posts: 2,851 PRO
When using a function like createPath(), that will throw "Edges do not form a continuous path." if given disjointed inputs, how would I best kill the regeneration and tell the user what's wrong? I feel like there's probably a simple way I'm not aware of. I'm currently trying this, but it doesn't seem to run the catch statement because downstream things just say "Variable path not found".
try
var path = constructPath(context, definition.curves);
catch (error)
regenError("Curves do not form a continuous path", ["curves"], definition.curves);
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    End the feature with a return?
  • EvanReeseEvanReese Member, Mentor Posts: 2,851 PRO
    I've not used "return" mid feature like that. good tip. My issue was that I was missing "throw" before the regenError() function.
