Using sheet-metal tools to make a bracket.
neeam_radianeeam_radia Member Posts: 3 EDU
I've designed this bracket to be made out of 2mm aluminium sheet. I would like to turn this into a sheet metal model (it's is currently plain extruded.) How would I do that? The sheet metal tool seems to be made for creating sheet metal cases rather than converting entire models into sheet metal like I need to do here.
  • glen_dewsburyglen_dewsbury Member Posts: 1,145 PRO
    Better I think to start this one as sheet metal. The second one is a convert if you prefer with flanges as cut outs.
    https://cad.onshape.com/documents/becbf8d99faea6d1f3a44ca6/w/a8497252213c5fe35717e0c3/e/7e8d6adc0776aa820f839f89
  • eric_pestyeric_pesty Member Posts: 2,314 PRO
    Converting to sheet metal should work fine, Onshape is actually really good at this.
    I would use the "thicken" option in the create sheet metal feature.
