How can i make 3 animate mate at time in a assembly? how can i make it?
in Simulation
Im making a 3 DOF Simulation Platform and i want to animate 3 bielas at time making a movement like loop for test the surfaces and distance…..
Its possible to make this 3 animate at time? how its possible? i try to " use" pinion relation but its no possible and error…. thank you so much
The movemente that i want to make its similar that this i show you in a final video:
Use the 'Gear Relation' in the assembly to link the revolute mates together
its posible tu create a gear with 2 DOF…. But its no possible for 3 DOF….
And how can i animate the “ gear” relation?? Thanks
Not sure if this is what you mean
https://cad.onshape.com/documents/b87169993955edaabf399752/w/4cc9c2e29b5801f161da41f5/e/7189ea64276a7e7aa227d666
If all it is is making them all turn the same way at the same time, the Gear relation is your tool as @GWS50 said. If you just want to check that the extremes of motion don't collide with anything as you work, Named Positions is probably an easier way to go. Just set them up once and click through them to make sure it's working. Onshape isn't currently made for complex animations, but if you are really determined, you can get it to do what you want using some workarounds which are well demonstrated by @john_mcclary in a video here.
