Sheet Metal functionality
bryan_lagrange
Member, User Group Leader Posts: 800 ✭✭✭✭✭
I know this has been discussed but I want to let Onshape designers know I can hear the chant from manufacturers.......WE WANT SHEET METAL! (insert clap clap clap clap clap sound) WE WANT SHEET METAL! (insert clap clap clap clap clap sound)...............Any time frame of this?????
4
Onshape knows the need for this but can't hurt to keep the pressure on.
It is also the Highest Voted Improvement Request: https://onshape.zendesk.com/hc/en-us/community/posts/202922330-Sheet-Metal-Features
So how can we make sheet metal awesome in Onshape?
Or, alternatively, what sucks about the sheet metal tools that you use now?
The more we understand about your workflows and challenges the better Onshape will be.
Feel free to post examples here or drop me a mail and we can discuss your requirements.
Sketch a bend and have a jog command.
Ability to bend and unbend in design mode to add specific features.
Set material thickness, bend radii, and K factor.
Normal to thickness cutout and hole command.
One button click to create a flat pattern and ability to create a .dxf directly from the flat pattern.
Different types of hem bends.
Add deformation features such as bend gusset, dimple, and louver.
2 corner and 3 corner close options to make water tight seals and the ability to add reliefs, offsets, and cutouts if necessary.
These features would be a good start.
Twitter: @BryanLAGdesign
With convert to sheet metal option add a rip corner feature.
Having the ability to add a cross break would be nice as well.
When creating a flange the following options would be nice.
Ability to designate bend to the inside, outside, or with an offset.
Ability to set the dimension as either an ID or OD flange length.
Option to select the bend to go:
1) Full width of the edge selected
2) Start from the center of the edge selected and symmetrically place a width
3) Start the flange from either end point of the edge and then set a specific width.
4) Select the edge and then set the width of the edge from both sides that will not contain the flange.
Additionally I would like to suggest options as given in below picture from Creo
