Distorted Loft
graham_lock
Member Posts: 265 PRO
Hi,
Referencing the image below:
You can see a simple loft, all sketch regions are of the same diameter.
There is distortion along its length.
What would be the best way to overcome this? I don't have any geometry to setup guides or paths? Or do I??
Thank you.
martin_kopplow
Member Posts: 1,212 PRO
Use guides and connections to eliminate the twist and distortion. One connection usually already does the job with simple geometry.
Thank you - connections did the trick!
