How can I add text in a Sketch that contains a Caron (e.g., Unicode U+030C (ǒ))?
mike_klaus623
Member Posts: 4 ✭
When I attempt to add text to a part which contains a letter with a Caron (e.g., Unicode U+030C (ǒ)), the resulting text appears as a small square instead of the actual letter. Are there Unicode characters in OnShape that can't be drawn?
GregBrown
Member, Onshape Employees, csevp, pcbaevp Posts: 374
What font are you using? Arimo, Didact Gothic, Inter, Michromata, MPLUSRounded1c, Noto Sans, Noto Sans Chinese Simplified, Noto Sans Chinese Traditional, Noto Sans Japanese, Noto Sans Korean, Noto Serif, Source Sans Pro and Tinos do show ǒ correctly.
[Edited to update the list of fonts that show correct ǒ character]3 -
mike_klaus623
Member Posts: 4 ✭
@GregBrown : OMG, thanks! I had randomly tried a several fonts that happened not to be any of those you listed. I gave up too soon. doh! I'm switching to Arimo. Thanks again!
1
Gregs answer helped me too, but surprisongly the first fonts from this list (Arimo, Didact Gothic) did not work. I mean, they just showed a placeholder instead of this arrrow ↺.
But 'Inter' worked for me (did not try further)
(…maybe someone has the same effect)
