Error: "Should be unreachable!"
Hello everyone,
I got the custom Featurescript "Form Sheetmetal" from @MBartlett21. We are using this on a daily Base to add embossing feet etc. Now I got a problem I´ve never seen. It says "Should be unreachable"… It worked the first time, but the error message appears with the second feature.
Does anyone had the same message before and could help?
Thanks!
Axel Kollmenter
MBartlett21 Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
It looks like you are using an older version, possible not from the original document. That error message is now a warning that you haven't selected a sheet metal part.
This could be to do with 'recent' changes to how Onshape's sheet metal works internally (i.e. the new corner break stuff, holes, etc.).
1
@Axel_Kollmenter
Link for reference:
Sheet Metal Forming Tool (MBartlett) | Feature Studio 1
We are currently using V0.4.1 . I will check the new version. Thank you!
Axel Kollmenter
@MBartlett21 Yes it worked with the newer Version V0.4.1 Thank you!
Axel Kollmenter
