Hidden lines on drawing not consistent with part
Hidden lines being displayed on the DWG are not consistent with the part geometry. For some reason, they are displaying wrong. Is there something I am missing?? They should be following the blue dashed line I drew over the DWG, not what is encircled by the red. I have tried to refresh, turn hidden lines on/off, etc…
  • S1monS1mon Member Posts: 4,061 PRO
    It looks like you might have used a loft with twisted connections and it's trying to display that. I would go back to the loft features and look that the iso lines, I bet they are not oriented the way you would expect.
  • David_MoultonDavid_Moulton Member Posts: 4
    The part wasn't lofted, it was revolved. However, it was imported from a SolidWorks part, and it's possible it could have reconstructed some of that geometry wrong when brought into onshape. Ill most likely cut that section out, and re loft or revolve the geometry back in.
