Gusset questions
eben_altoneben_alton Member Posts: 22
Hello, I'm wanting to put a gusset in the at the location pictured, but when I select the edge, it goes red. I'm not sure, nor can find the parameters that are required for it to work. I'm slowly working my way through the tutorials :) Thank you for the assistance.
  • jelte_steur_infojelte_steur_info Member Posts: 650 PRO
    edited November 2024 Answer ✓
    Gussets only work in frames to connect multiple lengths.
    In your case the rib feature could work, but it requires a sketch for the countour of the rib first.
    good luck! keep on trying!
  • eben_altoneben_alton Member Posts: 22
    Thank you! But that leads to another question I have been trying to figure out. It seems so simple I'm not sure why I can't figure it out! How do you draw the contour between the vertical and horizontal sections? I was hoping the gusset option would allow me to bypass trying to figure out how to sketch the angle in the first place :)
    Hmm as I posted, I suddenly realised how to do it, and it was simple, and I'm not sure why I didn't see it before. The brain is weird.
