Creating a Query from a Plane
graham_lock
Member Posts: 265 PRO
Hi,
I have the following code:
var horizontalPartSketchPlane = evFaceTangentPlane(context, {
"face" : face,
"parameter" : vector(0.5, 0.5)
var skHorizontalPart = newSketch(context, id + faceIndex + "skHorizontalPart", {
"sketchPlane" : horizontalPartSketchPlane as Query
Which fails at the sketchPlane attribute.
What's the correct way to convert the plane entity to a query please?
Thank you.
NeilCooke
Moderator, Onshape Employees Posts: 5,970
newSketchOnPlane (context is Context, id is Id, value is map) returns Sketch
Create a new sketch on a custom plane, specified by a
Planeobject. The sketch coordinate system will match the coordinate system of the plane.Parameter
Type
Additional Info
valuemapsketchPlanePlaneEXAMPLE
