Can someone explain what is happening here?
roger_m_kolaksroger_m_kolaks Member Posts: 30 ✭✭
This is a peculiar result that occurred when I applied MoveFace to a face of this shape. It happens only through a narrow range from about 0.39 cm to 0.50 cm.
I'm simply curious how the app might be interpreting the transformation that would yield this result.
The construction is in the tab labeled "hex versus square" in the linked document.
https://cad.onshape.com/documents/583844fc9a551b6fcdee2773/w/648b6166e90f18cec04283cc/e/94eb6c0c1fded460b3949511?renderMode=0&uiState=67425dc26162a96fb0dcf171
