Circular Pattern with Move Face feature
I'm trying to create a circular pattern here with the a move face feature, but the circular pattern always fails:
https://cad.onshape.com/documents/233ece5bf67e5cfd0ff9829e/w/f4926fc63ae73655e27fb075/e/38e1cfc768a63f39d9d15e33
Doesn't give much of an error message, so not sure what the issue is; I've used circular pattern with features before without issues, not sure why this one fails.
Also tried a circular pattern with the faces selected and that didn't work either.
  • MDesignMDesign Member Posts: 1,265 PRO
    It's confused on what do with this area. maybe recreate that with some other way than the move face and it might work
  • jelte_steur_infojelte_steur_info Member Posts: 605 PRO
    it's worth a try with a face pattern, rather then a feature pattern.
    in feature pattern, perhaps the split face needs to be included. worth a try but may not solve it.
    if you create an extrude (new body) with this custom feature:
    https://cad.onshape.com/documents/24819ddab7dc83c810eb8246/v/b409220bda82b907cd49f383/e/38727ba0d05188ebe79387a5
    you could use a part pattern, then subtract in the circular pattern.
    also likely the Regional pattern feature will also work.
    https://cad.onshape.com/documents/c075acc6fb32c0edf21a3124/w/ddb79a252f789ff122711f0c/e/d28197b22d767a9eb79bfb32
  • glen_dewsburyglen_dewsbury Member Posts: 1,223 PRO
    Here's a thought.
    1. Replace revolve face with solid to eliminate close operation.
    2. Change revolve to symmetric 360/8deg.
    3. Fix split and move face.
    4. Circular array of part/add.
    https://cad.onshape.com/documents/4ed7c20a665c1deb6acbeb0d/w/12dc68bb6ab653d522c7c988/e/604ad8636b745bfb1ca77e5d
  • david_airthdavid_airth Member Posts: 4
    Yes, it look like this is an alternate way of completing this shape, seems weird the other way wasn't able to resolve, but :shrug.
    Thanks for the help!
