Editing an Extrusion
william_turleywilliam_turley Member Posts: 9
Does anyone know the best method to make the middle section (9mm)
Desktop Screenshot 2024.11.28 - 23.03.02.01.png Desktop Screenshot 2024.11.28 - 23.03.14.57.png
of this a regular rod while leaving just the ends (3mm on each side) cut?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,060 PRO
    edited November 2024 Answer ✓
    On your first extrude, pick both regions of the sketch, to make a complete circle extrusion.
    Now, unhide the sketch (the extrude command will hide it).
    Now make a second extrude, only picking the slot portion of the sketch, and make it a 3mm long cut. On the right end of the part, do the same thing, but pick the right face as the starting offset inside the extrude command.
