How to change the angle of an intersection?
w_s856
Member Posts: 58 ✭
I am designing a cable rack for my USB cables: https://cad.onshape.com/documents/cca8593f8f0eebf79d365427/w/3c7b213d35aa920ec20af127/e/fb843cbaebfbea3c5aab45f2?renderMode=0&uiState=674cc1582d061c03822b7bd3
A first printout showed that it is good, but I would like to tilt the rack part a little bit up, so that the cables naturally slide towards the inner end of the rack (and do not slide out and fall):
This would require the 90° angle to be changed to a smaller one, is this something I can do in a straightforward way?
As a workaround, I imagine recreating the rack part on a tilted plane but would like to make sure that the angle is not modifiable in an easier way before jumping in (this will be a good exercise anyway)
like that?
https://cad.onshape.com/documents/166ad0976e069278c9ba7065/w/8cbf140a9d243b4452d15c1d/e/c9748c3d7734b9f4e41a6adf?renderMode=0&tangentEdgeStyle=1&uiState=674cd6cf74604871e44552ae
A move face/rotate will do what you want.
https://cad.onshape.com/documents/c0cc7fc331232927db66e30e/w/29a51cb749a69189437020eb/e/18c0195f7b527c806865fa0d
Take note of the 'extrude angle' sketch and the direction option in the Extrude feature. - Scotty
Document
