Setting / sharing variable studio variables
graham_lockgraham_lock Member Posts: 265 PRO
Hi,
As I understand it, setVariable sets variables in the context which is fine if the variables are only required to be shared between features within the current document, but is it possible to create / update variable studio variables in FS to share across multiple documents?
Thank you.
  • MichaelPascoeMichaelPascoe Member Posts: 2,803 PRO
    Standard part studio variables can't be shared directly across documents. You would need to use the variable studio for this. The problem with the variable studio is that you can't access it from FS or measure values to it.
    You can store the variables as an attribute within a part, derive that part to another document, then retrieve the variable from the attribute of the part. Alex made a great feature for this called: Variable Library
    RENDERCAD
    RENDERCAD
  • graham_lockgraham_lock Member Posts: 265 PRO
    Thank you.
