Improvements to Onshape - November 22nd, 2024
2»
  • SebastianMaklary
    SebastianMaklary Member Posts: 37 PRO
    Flatten surface is an important capability and I am happy to see it implemented, though as others, I would prefer if it could be a feature that would create a surface body.
    For now though, It means that another reason for keep visiting our Solidworks license is no longer valid.
  • sebastian_glanzner
    sebastian_glanzner Member, Developers Posts: 498 PRO
    edited November 2024
    Great updates, thank you Onshape team!
    You actually can flatten cones! But I would really like it to be implemented in the sheet metal tools.
  • Hfrossard
    Hfrossard Member Posts: 13 PRO
    Easily one of the best upgrades I have come across.
  • GregBrown
    Thanks for all the feedback on this new feature. If you have improvement requests like the one you mention here, we'd love to get them in the system the normal way…
  • joshtargo
    joshtargo Member Posts: 693 EDU
    @sebastian_glanzner my Extract Flat FS does sheet metal.
    https://cad.onshape.com/documents/ee5fe3705045d8cf9e3fe478/w/6c8344d774ce4c4c0e00ad7e/e/2e3c34069cc7000fbe02adb9
  • Lucas_Kuhns
    Lucas_Kuhns Member, csevp Posts: 109 PRO
    Very nice update. I like the sketch profile inspector and pause regen!
  • eric_pesty
    I created an IR for flatten surface to be a feature… Go vote for it!
    https://forum.onshape.com/discussion/25980/make-flatten-surface-into-a-feature-that-creates-a-surface-in-the-part-studio#latest
  • AEC
    AEC Member Posts: 24 ✭✭
    Christmas is early this year, thickness analysis tool 🤤 amazing!
  • JosefBurjeta
    JosefBurjeta Member Posts: 30 PRO
    Checking the changelog, there shall be an update regarding pasting tables from Google Sheets or MS Excel. There's definitely some improvement done, but a lot is still missing.
    Changelog: Support styling (bold, italic, cell colors ..) and cell width/height on paste from Excel/GSheets in Drawings
    • Bold, italic, underline, strikethrough works
    • Other types of styles unfortunately did not improve
    • Cell height/width is somewhat changing, but is definitely not the same as from input
    • Font size is not computed correctly from "pt" to "mm" (I believe that's why the cell sizing is wrong as well)
    Thanks for looking into this 🙂
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,115 PRO
    Very nice update!
    Some of my favorites this round, the very special ones are bold or italic :)
    1. New flatten surface export
    2. New Sketch profile inspector tool
    3. New Paused regeneration mode for Part Studios!!
    4. Support for Thickness Analysis for Professional and Enterprise Edu users
    5. Support including decals in thumbnails
    6. Support styling (bold, italic, cell colors ..) and cell width/height on paste from Excel/GSheets in Drawings
    7. Render Studio: Select all instances of Part or sub Assembly
    I think the Onshape crew was hoping their name gets brought up this year at the Thanksgiving table when everyone says what they are thankful for 😉
    Can't wait to see what they do for Christmas, unless they take a well-deserved break for December's release.
  • christian_petty
    christian_petty Member Posts: 91 PRO
    Agreed—this could be useful for molds or jigs.
    Christian Petty - Mech. Design Engineer, Radian R&D
  • pmc_pmc
    pmc_pmc Member Posts: 11 ✭✭
    Flatten, pause regen, sketch inspector for small gaps, and useful bezier degree reduction are all relevant for a current project.
    Not the first but maybe the most dramatic instance of JIT functionality in Onshape. :)
  • adam_geary
    adam_geary Member, csevp Posts: 43 PRO
    Oh I'll definitely be using that flatten surfaces tool in the future. I've always wanted that! And I have to deal with complex dxfs all the time, so the sketch inspector will be great.
    S1mon Member Posts: 4,615 PRO
    @ilya_baran Thanks for sharing that. It's fascinating to see the background for new functionality like this.
    1. Was this implemented in FeatureScript or something else?
    2. Will it be possible to tweak any of the parameters in the future?
    3. Has it been benchmarked against any of the other tools out there for accuracy in real materials?
  • andrew_kleinert
    andrew_kleinert Member Posts: 97 PRO
    A guess about why OS have done it this way …
    … It provides OS with the flexibility to change functionality of this later. They can change assumptions, change default behaviour, change functionality, or even add functionality without having to worry about backward compatibility.
    If they had allowed it to be integrated into the parametric tree, and then made changes to functionality later, users would rightfully get very upset if a parametric model that was perfectly fine yesterday / last week / last month / last year is today either materially different or even broken for no apparent reason other than a software update. OS could create model migration filters to handle changes (as they have done in the past), but that adds more development, testing, processing (and risk) that is probably better spent elsewhere.
    There is the possibility that the export - import functionality that has been implemented here could result in a different outcome between versions, but as this is a manual process under user control, there is far less risk of this leading to user angst. Us users expect to have to fix something up whenever we re-import it.
    Edit: What Ilya said.
  • Henk_de_Vlaam
    Henk_de_Vlaam Member, Developers Posts: 269 ✭✭✭
    Until today I thought the new ‘Profile inspector’ button in the Sketch panel would only work on imported DXF sketches, because on open self-drawn sketches the button did not respond. Until I discovered that there is another button that needs to be pressed before the inspector panel appears.
    Is there a reason for this (second) extra button? Can’t it just be dropped and just let the button in the Sketch panel do its expected job?
  • eric_pesty
    My guess is that they are planning on adding other sketch "diagnostic tools" under that button, with "profile inspector" being the first… (kind of like the "analysis tools" expands into curve/surface, dihedral, zebra stripes, etc…)
    I hadn't realized this but that has interesting implications!
  • qnguyen
    qnguyen Member, pcbaevp Posts: 4 PRO
    Flatten surfaces is my new hero, especially for some sheet metal work from external CAD models, etc…
  • Lucas_Kuhns
    I just recently learned that we are able to "convert" an imported sheet metal part into an Onshape SM part. You just have to use the Sheet Metal tool > Thicken > select the main face > make sure thickness and direction are correct > Tangent propagation checkbox. This creates a new part but then you have the ability to add flanges, tabs, etc.
  • qnguyen
    Hi Lucas, thanks for you advise. Our team still doing that while some of other departments would want to get 1-3 clicks to get the dxf from our old CAD model from SolidWorks before. But yes, good approaches both ways
  • gonzalo_chomon
    gonzalo_chomon OS Professional Posts: 56 ✭✭✭
    Thanks to the whole Onshape team for the new analysis tool.
    I have been waiting for this for years.
    I did not need such a powerful tool, something simpler would have made me happy and your great community. But I understand your actual professional compromises.
