Help with simulate a force load
https://cad.onshape.com/documents/14a4cc1182d0980175a4fa18/w/09699c0940926046713b6e0e/e/b6355ed00a422ae6e0867be5?renderMode=10&uiState=6752e80b1e8dfc77405a6373
I'm working with a wheel rolling on a flat surface. When I tilt the flat surface back and forth, the wheel rolls accordingly.
Now, I want to simulate the effect of a force applied at one extremity of the flat surface, expecting it to cause the surface to tilt and, consequently, the wheel to roll. However, when I attempt this in my simulation, I encounter a generic error message stating, "simulation did not converge."
Could you help me understand why the simulation is not converging and suggest potential solutions to fix this issue?
    Stress Simulations are for static stress analysis only - this means no moving parts. If you need to do kinematics and collision detection you'll need to use different software.
  • joshtargojoshtargo Member Posts: 329 EDU
    edited December 2024
    tangentially, I wrote a statics solver for rigid bodies. But nothing is moving (hence "statics").
    Statics Solver
    https://cad.onshape.com/documents/9e81e5d8e71227cf44c561b6/w/b644076af57215e652a8e7f3/e/6044abd6f98daf7912f567d6
  • Shiv_Charan_MadanShiv_Charan_Madan Member Posts: 2 PRO
    @joshtargo Just curious to know that how do I view the resultant forces on a line or a point due to applied force if it is possible.
