Cylindrical cam / barrel cam / end cam
andrew_andrewm
Member Posts: 4 ✭
in Drawings
Figure 6.5 here https://www.cs.cmu.edu/~rapidproto/mechanisms/chpt6.html
or
http://knowledgestream.co.in/motion-simulation.html
Did a bit of searching to work out if I could do this in OnShape and came up with not much
I would like to draw a sketch on a plane that is the cam profile. then wrap that plane around a cylinder and the extrude towards the centre of the cylinder.
Found one thing in the forums that was in a similar theme.
https://forum.onshape.com/discussion/comment/1322#Comment_1324
Or am I going about this the wrong way and is there a tool for already doing this ?
or
Optionsandrew_troup Member, Mentor Posts: 1,584 ✭✭✭✭✭Here's a kludge which is probably better than nothing, but elegant it ain't
https://cad.onshape.com/documents/23ea467e79014d19b4097729/w/942d64b50cdb4baf9889844e/e/6ae350e800ce47ec916a098a
5
https://cad.onshape.com/help/#assembly_mates_video.htm?TocPath=Onshape%20Videos|_____11
There are some threads which might also help you.
https://forum.onshape.com/discussion/comment/10387#Comment_10387
https://forum.onshape.com/discussion/comment/10327#Comment_10327
I simply can not work out how to get the cam profile slot cut into the outside of a cylinder.
Looking at the simple barrel cam in the first example you gave, I've done something similar (but with more turns) here: https://cad.onshape.com/documents/4e2b48617bac491892ede2e8/w/fa394ea193d24761b423bb68 (public document, Grooved drum traverse roller)
I did this with a helix as the swept path. If you open the model and run through each stage of the process using the roll-back bar you can get an idea of how it was done.
For a cam profile, you could just change the shape of the swept sketch to suit.
Stuart
Once we have 3D splines, and can use them to trim (cylindrical, in this case) surfaces, a workaround will be relatively straightforward.
Hopefully someone clever will prove me wrong and come up with something elegant using Onshape's existing feature set...
Here's a part of a barrel cam I've just worked up - https://cad.onshape.com/documents/d5d2b1350b0348f8b1c4d5af/w/fce5620005a842d18c0c523f
I was just throwing curves onto the face of the cylinder using Surface extruded from tangent planes to make a sweep path, so it's not a mathematically-worked-out cam curve, just a way of doing it.
Did you remember to share it as "Public" ?
Apologies - had saved & removed history (space premium!) and failed to make the copy public.
Here: https://cad.onshape.com/documents/d5d2b1350b0348f8b1c4d5af/w/fce5620005a842d18c0c523f
and a new version v2 here: https://cad.onshape.com/documents/96818aab68d044bcad562b21/w/7a4fb0f58dff4bea914b8f1b
I may make the V2 more complex by making the arcs in sketch 2 & 3 smaller, then creating two more planes through where their projected surfaces touch the face, offset the planes, then join the ends of the original surfaces with two more projected surfaces to use all as sweep path. that should make the sweep more of an 'S' shape.
That seems to me a nice method for the case where the required groove is semicircular in profile, and when direct entry of polar coordinates is not an essential requirement.
Thanks both for that. It is certainly closer to what I want than I was able to work out how.
Sadly I think because the projection to the cylinder is from a flat plane and not wrapped around the cylinder I won't be able to use that to generate the required cam profile.
BTW - I did just find a video with a cylindrical cam closer to what I actually want than the previous examples. It is "The Engineer Guy" showing a parker retractable pen.
https://www.youtube.com/watch?v=MhVw-MHGv4s
The other use case people might be familiar with is a cylindrical cam in cheap consumer items like digital cameras and inkjet printers. They need to save money (or size) by reducing the number of motors. They have a one way clutch that when the motor is spinning backwards the cam is indexed. The cam engages a different mechanism at each index point. The motor is then forward to power the newly engaged mechanism. Many functions all from one motor.
If the polygon in Sketch 1 had 36 sides, you could input coordinates in 10deg increments, or 5deg by snapping to midpoints.
Having said that, it's unquestionably laborious enough that it would only appeal to someone with a pressing need an Onshape solution for a non-helical barrel cam. The Parker example you now say you want to copy uses multiple teeth of helical axial cam form, so Stuart had already nailed it (conceptually) with his first post.
My way is a general solution, so it would also work for a helical cam tooth
(in the Parker analog to a "snail" cam, using two discontinuous surface lofts per tooth)
but the setup would be tougher than simply using a helix, with no commensurate benefit.
However in OpenSCAD I can get a script to type up the code for me and then cut and paste it - so it is not so labour intensive to do one point per 2 degrees of rotation.
I agree it would be a lot of labour to do with Onshape with no way to automate entries like this to the GUI.
The cam profile I need is not a straight helix. It does have varying acceleration and dwells as well as the discontinuity. So your "general purpose solution" would be the way to go.
I've adjusted the groove on example Barrel Cam V3 here, https://cad.onshape.com/documents/6ce2565a7ffa47c48983a1c7/w/ab71b3dcf4554d899abd9103
It's now using a projected spline curve (using a surface to part command) to give a nicer profile that can be adjusted by manipulating the spline.
I've spent a bit of time trying to model an End Cam as drawn in the links in the first post of this thread, and this is the nearest I have come: https://cad.onshape.com/documents/2f0b6e6a83da42899ce51fd1/w/3a677a069d914bf7a7f68de7
If anyone can work out how to fill the semi-circular groove (or stretch a surface between the inner and outer top edges) then I think it's very close to what was wanted.
It is very easy to provide two surfaces which blank off the groove visually; it's just a matter of lofting a (blue) surface from the inner to the outer edge of your groove, as shown by the edges highlighted in the graphic, and then doing the same for the other pair of edges to produce the yellow surface.
Unfortunately there is (AFAIK) currently no way to combine those two surfaces into one. ("Knit", in Solidworks) If this could be done, the two faces of your groove could be selected for "Replace Face", and replaced with that single combined surface, providing the result you seek. (Replace face can replace multiple faces with a single surface, but not with multiple surfaces.)
BTW, the generalised method I posted above can be used to produce the end cam (as a solid) very easily
Refer public model:
https://cad.onshape.com/documents/73ba229cd7204ed4a803e0c3/w/652f1d601aa54b39b177c521/e/8a9e9ff8fbf6492686d07050
I threw together a quick and dirty demo in part studio 2 starting with a derived copy of the model you posted above, but it could just as easily have been modelled from scratch.
In my example, the lofted surface was used to extrude "up to", but it could equally have been used to split a full height hollow cylinder.
Note that I set end conditions for the surface loft as normal to the plane of symmetry, otherwise the result would not have been smooth across that plane.
Unfortunately Onshape does not (yet) permit lofting a single surface as a closed loop, so we are still stuck with the two unwanted edges crossing that plane.
Part Studio 1 shows how I added the surfaces shown in my immediately previous post to your model.
Which doesn't actually help in this particular case, as my method is effectively a way of getting Onshape to infer a guide curve from the locations of the loft profiles, and the imposition of end conditions
Onshape has to infer a guide curve because (in the absence of 3D curves) the user is currently unable to provide one in this case.
Returning to what IS currently possible in Onshape: The closed guide curve can be split if it is in a single sketch, but there seems no Onshape way of picking multiple curves to specify a guide curve (there are several ways to do this in SW: composite curve, convert to 3D sketch curves, or use Selection manager to build the guide curve).
If this were possible then a single closed loop surface could be lofted to replace the two in my last-post-but-one, picking the two-piece inner and outer curves to act as guide curves, and the straight lines as loft profiles
