Help - Why does not this extrusion work?
tomas_hellströmtomas_hellström Member Posts: 4
Hi!
I am struggling with the following extrusion. fi want the base face extrude to the face of the other part that is a cylinder. I need some direction how to fix this. Thanks in advance for any type of input.
  • EvanReeseEvanReese Member, Mentor Posts: 2,373 ✭✭✭✭✭
    it looks like it's tangent to the cylinder, which makes it impossible to merge with it. Either make them overlap, or change the feature to New instead of Add.
  • tomas_hellströmtomas_hellström Member Posts: 4
    Thanks for your input. I actually managed to solve it by extruding it both ways. Into itself with 0.1 mm and to face. Then I could use the Add option. Not sure why that worked but might have to do with your suggestion.
