How to make a slotted hole
jan_diddenjan_didden Member Posts: 12
New user here, progressing slowly.
How do I make a slotted hole? It would look like two opposing half circles connected by two straight lines. Something like the attached which I found in an existing design. Grateful for any pointers.
Jan Didden
  • glen_dewsburyglen_dewsbury Member Posts: 1,084 PRO
    Slot tool.
  • jan_diddenjan_didden Member Posts: 12
    Yes, I know that slot tool. My question was how to actually make a slot on a sketch. Do I first have to draw a line or a point? Just clicking the slot tool and then trying to draw doesn't give me anything.
    Jan
    Yes, you first need a line. Then use the slot tool on the line -it uses the line as a centreline for the slot, with the radii centred on the endpoints of the line.
    You can also select splines and arcs, not just a line.
    Have you tried the learning center? This and many other sketching techniques are covered in sketch training for free.
    Also if you hover the mouse over the tool selection you'll get a brief description. In this instance the description is "make a slot by selecting line, spline or arc". They can be used in combination as well.
    https://learn.onshape.com/
    Yes, I got that far. Drew a line on a sketch and put a slot around it. But I keep getting error messages like 'not fully defined' and the slot remains red in the list of items. I can extrude it 'through all' and it looks OK but the outline remains in blue and I can't get the dimensions/position to display.
    Jan
    @jan_didden
    Is the centerline selected for the slot completely constrained? See the difference between sketch 1 & 2 in this example. Sketch 2 shows as not fully constrained even though its the same. In sketch 1 the centerline is constrained.
    If you are seeing red in the sketch feature list post a link to your document for a review since something else is wrong. Maybe something over defined?
    https://cad.onshape.com/documents/ac0ecfe4f301c56899904542/w/f485e7914d309ca0473669c7/e/d63eab67f229ebc830cb3e5c
    Hmmm. I need to learn what 'constrained' means, and how to manipulate it.Thanks guys, I now have a direction!
    Jan
  • Ste_WilsonSte_Wilson Member Posts: 482 EDU
    With help from my friend Cor van Doorn, I have it like I want. Had some error messages like 'not completely regenerated' and 'undefined' but now understood their origin and solved them. I also understand why all elements have to be constrained to something, that was a new concept I needed some time to grok. Onwards, always onwards!
    Jan
  • jelte_steur814jelte_steur814 Member Posts: 501 PRO
    Since google leads people here when asked 'how to create a slot'
    there's a new featurescript. make a hole (with the hole feature) and turn it into a slot.
    hole to slot feature
    give it a try and let me know if it works for you.
