How do I add a button flush to a cone?
iKry
Member Posts: 3 ✭
Hello I'm very new to OnShape and am having a hard time just trying to add a button to a drafted cylinder. I've tried so many different methods, but can't quite seem to get it to even form a shape. I'm hoping someone can help me! The button needs to be curved which adds an extra layer of complexity. I've attached a photo of the (many) sketches I used to try to loft, attempted the "fold" feature, projected curves, and even tried wrapping (but because it's not a perfect cylinder it doesn't work). I also added a photo of what I'm trying to recreate (because the model out of context photo is a little questionable).
https://cad.onshape.com/documents/db9977f7ad711b1e462cd31d/w/342479af99dd49ccc94802f9/e/be14c70c31529411c5689c97?renderMode=0&uiState=6759e71325831213e95fd2e5
jelte_steur_info
Member Posts: 655 PRO
here are two options. one with a strictly circular base and some surfacing work. (not the best, but i think good enough for this application)
and a simpler one; revolve 3. revolves and adds a sketch that you've drawn earlier.
https://cad.onshape.com/documents/eb8cfff5e9ab0e87506a7c71/w/2c1319d0f47d5f620c6cc009/e/2e68e55a2f05a0bb49812f4c?configuration=List_9H2izHPOuMxLMc%3Dcircular_based_surfaces&renderMode=0&rightPanel=configPanel&uiState=675ab697333530409c55adae
