Sketch one not fully defined on "Keyboard Kickstand" part
Just starting out in onshape with limited cad experience. Designing a small "kickstand" missing from my keyboard. Can anyone tell me what I need to do to correct this? Not sure how to direct you to the part, except it is in the public section under "Keyboard Kickstand"
  • jelte_steur_infojelte_steur_info Member Posts: 650 PRO
    look for the blue stuff; those are the undefined geometries.
    I found this in the corner where you also define the 90 degrees. (tip: perpendicular constraint is cleaner, unless you want to vary this angle)
    these line endings are not coïncident, or missing a tangent constraint perhaps…
  • charles_castlecharles_castle Member Posts: 5
    Thanks so much — I changed the definition from 90 degrees to perpendicular. But I'm not sure how to fix the line endings — any suggestions would really be appreciated!
  • MDesignMDesign Member Posts: 1,328 PRO
    edited December 2024 Answer ✓
    assign and coincident constraint or just drag drop them on to each other that you want to be coincident. looks like they should probably be set to tangent as well
    Yea! It worked! Thanks so much for your assistance! It is appreciated!!! (Happy Holidays!)
