Trying to make open irregular container
st_shst_sh Member Posts: 7
Hi everyone,
I'm trying to build a container. This is my sketch:
https://cad.onshape.com/documents/d1562c583638f2639501b91d/w/26524bef232a3c8069f11d40/e/310bc66d5ac56dbc72169ddc?renderMode=0&uiState=675a90524a4a43331b88530a
I've achieved a black outline, and then I copied and edited the shape again and placed it within the original shape to achieve 1.2mm walls.
I'd like to extrude the outer shape first, then the inner shape to hollow it out but first I think I need to move the smaller (internal) shape 1.2mm away from the front plane, leaving a solid wall, and then extrude the inside to 1.2mm from the opposite side to achieve another wall there. I'm very new to this so I am not sure if I'm even on the right track.
Any advice would be appreciated. Thanks!
