opPlane
Goldorak_56Goldorak_56 Member Posts: 4 ✭✭
Hi,
I have used OpPlane operation in a feature script but i can't manage to display the name of the plane on screen as opposed to the feature Plane.
Can someone help me on this topic please ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,956 image
    Yep it detects the feature name cPlane which was hard coded on day one. Please create an IR (please).
  • EvanReeseEvanReese Member, Mentor Posts: 2,774 PRO
    I'm really not sure how to do this actually. I was curious so I went poking around the code of the native plane feature to see how it's done and didn't notice anything special. Next, I duplicated that code to my own feature studio and it still displayed names on creation. I changed the feature function name from cPlane to cPlaneTest and the names disappeared from planes created by it. This seems to point to some backend solution for it outside of FeatureScript for the native feature.
  • Goldorak_56Goldorak_56 Member Posts: 4 ✭✭
    Hi,
    Thank you for your answer. I have created the IR but the support doesn't seem to consider this as an IR :(.
    To find a work around, i would like to rename the plane created in my feature which is named Plane1 for the moment. Do you know a way to rename a plane created thanks to OpPlane ?
    Thank you in advance for your answer.
