Configuration in drawings
franco_otaolafranco_otaola Member Posts: 23
hello,
i am trying to put the "configuration" in the drawing so i have the different dimenssions in each drawing and at the same time i know witch one it is....
like in a text balloon (note) i would like to put the name of the imput list of the configuration i had chosen and a variable that is in the configuration.
(also if i can use the variable values in the part studio to put it in the table)
thanks
  • franco_otaolafranco_otaola Member Posts: 23
    thanks!!
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,959 PRO
    Welcome  :)
  • os_tnt_mrnos_tnt_mrn Member Posts: 9
    The configured part properties works well enough to use a blank property like Title 1, however, if you have two or more configured profiles you can't have another blank property on the other configured table. The posts above are from 2018, are there newer methods to address drawings that reference the specific configuration and somehow include the name within the drawing?
