How to Linear Pattern a Slot across a Face
alex_drozdalex_drozd Member Posts: 6
Hi,
I want to linear Pattern a slot across a face. This is my work flow. Sketch, Remove Material, Linear Pattern. I've done this many times in other CAD packages but can't figure out how to do it here. I want the slot to multiply across the rest of the part, but as you can see it stops if it is not a "full pattern", even though my initial sketch, which extends beyond the part, doesn't carry forward.
Thank you.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 698 EDU
    Try clicking "Reapply features."
  • eric_pestyeric_pesty Member Posts: 2,296 PRO
    Check the "reapply features checkbox.
  • james_aguilar160james_aguilar160 Member Posts: 57 ✭✭
    Have you tried clicking reapply features? That's always my first thing I try when I encounter "hey this feature pattern isn't working the way I want it to."
  • alex_drozdalex_drozd Member Posts: 6
    Thank you so much! I would have never figured this one out.
