Accessing students work
Are you able to access students work on my teacher computer to assist them while the student is currently working on the same file or does the student have to submit the file before the teacher can access it?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    That depends if you have the Enterprise version or not. If not, the student will have to share the doc with you.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 618
    If you are using Classes & Assignments, you are automatically shared on student documents associated with assignments. If the student is working on the document, you can jump into the same document no problem. If there are multiple versions or branches, make sure you are in the same workspace as the student if you want to see their most recent work. Also, you can use follow mode to see the student's work in real time or vice versa!
  • james_fajksjames_fajks Member Posts: 4
    Thank you very much
