I have all my files locked up in rsdoc format. When will I be able to import them and convert?
Hi, is there any option to import geometry from DesignSpark Mechanical? I have all my designs locked up in the proprietary format and I am kind of trapped in the ecosystem as a consequence.
I can export STLs but that is not geometry.
Thank you.
Thank you.
michał_1 Member, Developers Posts: 215 ✭✭✭
Try to get Spaceclaim trial, open your rsdoc files and export them as step. If Spaceclaim won't read rsdoc then just retype rsdoc to scdoc, Spaceclaim will see that file as it own native file. If whole "operation" is one time event, because you're switching to Onshape permanently, it worth checking. You can also ask some guys from DesignSpark forum to translate your files. I've seen similar requests on their forum and there was always someone eager to help.5
Other users have worked around this by importing their STL files into another package (like FreeCAD) and then exporting out of that software. In fact, another Onshape user has a blog post on this.
http://anoved.net/2015/07/import-stl-models-to-onshape-part-studios-using-freecad/
https://cad.onshape.com/help/#translation.htm%3FTocPath%3DImporting%2520%2526%2520Exporting%2520Files%7C_____4
projektowanieproduktow.wordpress.com
michał_1: That is actually an obvious solution that somehow evaded me. And that considering that I went to great lengths to find a solution for this up to extracting the geometry data via a series of file conversions like explained on this freecad forum thread.
