Sketch from Flat pattern
steve_maiettasteve_maietta Member Posts: 54 PRO
Generating a sketch from sheetmetal flat pattern.  So I could easily add tabs, flaps etc.
  Either using the "project" tool or a one click convert would be nice and useful.
Otherwise it's not apparently possible without putting the pattern into an assembly and then generating a sketch from that.  Which works but kinda clunky.
thanks
~Steve
    @steve_maietta you may find this approach similarly clunky, but I sketched directly on the sheet metal pattern using the Project tool.  Then I inserted a Derived Part (in a 2nd Part Studio), selecting the sketch previously projected from the sheet metal pattern.
    This seems to work.  The derived sketch scales associatively with the sheet metal part:
  • steve_maiettasteve_maietta Member Posts: 54 PRO
    matthew_stacy
     That works similarly to other workarounds.  (create part studio in context, from assembly). Thanks for the idea.
    PROBLEM!  with both methods though...ugh, which doesn't really show up until export into other software. .
    --When projecting from these derived views into a new sketch, all perimeter lines come up doubled.  I'm assuming the software is projecting from both faces of the flat pattern and so getting two edges.
    Dealing with all these many many doubled lines is a nightmare.
    setting up drawing of a pattern works fine, single lines.
    extruding my sketch into parts, then creating a drawing of them works fine as well.
    So once again, a way to PROJECT a PATTERN as a FLAT SKETCH would be A+ awesome.  even just perimeter. Or maybe an option for perimeter + bend centerlines.. or whatever. . .
    thanks
    ~Steve
  • lanalana Onshape Employees Posts: 727
    @steve_maietta
    Please write an Improvement Request for this functionality.
  • Alina_LoscherAlina_Loscher Member Posts: 1 PRO
    edited December 2024
  • GrobGrob Member Posts: 2
    Thanks guys,
    It worked for me, Not the most elegant but worked. Maybe more as a note for my future self on the steps of how it can be done.
    -Open as flattened part as an Assembly,
    -Select the flattened part > "Create Part Studio in Context"
    -Then in the new Part Studio tab, Create a Sketch on the part and use the "Use(Project)" tool to create an outline of the flattened part.
    Then do what ever mods you need to do and re-extrude.
