I can't find a way to add a cover with a thru hole pattern on a cylindrical shell with gasket
end cap won't work for me, extrude ring over gasket and add-extrude to fill the missing solid won't work for me.
I am stumped
https://cad.onshape.com/documents/1a9132b186d8693c77c44db5/w/a060c2cd16d777366420404c/e/6ad0c0a1c59511f747ad2c2c?renderMode=0&uiState=67696c80556cd502565e40ba
  • robert_scott_jr_robert_scott_jr_ Member Posts: 583 ✭✭✭
    Hey Christopher. The sketch 'set point for 1st hole' should be on the surface of the cover. - Scotty
    Document
  • Christopher_MoutoulasChristopher_Moutoulas Member Posts: 34 PRO
    Hi Scotty
    I posted the dynamic link, and my question is moot because I found a way to make the cover (extrude with offset off the plane at the origin)
    The above screenshot doesn't apply any more
    hi Scotty
    that's the point for the first threaded hole on the cylinder shell rim
