Sketch Intersection
graham_lock
Member Posts: 265 PRO
Hi,
I'm sure this is really simple and I'm missing something but:
If I have for example a line drawn on the right plane and I want to know where that line intersects the front plane so it can be used as a reference for further geometry how should it be done?
Thank you.
NeilCooke
Moderator, Onshape Employees Posts: 5,927
Pierce constraint in sketch. Create a point and add the constraint between that and the line.
Senior Director, Technical Services, EMEA0
Thank you.
