Placing Derived Parts in an Assembly
alex_drozdalex_drozd Member Posts: 6
I want to use a Master Sketch to drive an assembly, so I make 3 individual derived parts using a Master Sketch. Now I insert them into an assembly. I know usually I would fix one, and position the others with mates. But wouldn't using mates in this case override the benefits of the Master Sketch?
When I make changes to the spacing between the parts in the Master Sketch, the Assembly doesn't reflect it because the Mates are holding their position.
The way I got it to work in the Assembly was to insert the parts and applying the Fix command to all 3 parts without any mates. Now when I change the distance between the parts, they follow the Master Sketch correctly even though I get a warning saying I have too many Fixed parts.
Am I missing something here, or is Fixing all the parts the correct workflow in order to replicate the Master Sketch?
  • eric_pestyeric_pesty Member Posts: 2,296 PRO
    You can insert your master sketch into the assembly and mate the parts to it.
    Or add explicit mate connectors to the parts (based on a common reference on the master sketch)
  • alex_drozdalex_drozd Member Posts: 6
    Thank you!!!!! I should have thought of that.
