resolved
Christopher_Moutoulas
Member Posts: 40 PRO
What you have selected are edges. If you want to extrude edges to create a surface perpendicular to the face you will need to select "Surface" at the top of the UI where it reads "Solid | Surface | Thin " .
If you want extrude the face then you need to select the face not the edges.
