Adding a rubber seal to a box
gehejogehejo Member Posts: 5 EDU
Hello, I'm fairly new to CAD so I'm hoping there is something simple I'm missing here.
I have a box with a lid and I'd like to use a 1mm round rubber seal where the box and lid come together. I can get the seal cutout around 3 sides of the box, but when I push the extrusion on the 4th side the full length of the side, it causes the first side to move up and I'm not sure what I'm doing wrong. I can fix it by removing the mid-point contraints on all of my sketch circles, but I thought that wasn't good practice. What am I doing wrong here in my approach?
  • rick_randallrick_randall Member Posts: 417 ✭✭✭
    Looks like your issue is with a mid-point constraint being used after an operation has renamed the original line. I would suggest using a sketch, and profile, to sweep subtract that profile all in one operation. This might require some different planes and sketches, but still might be easier in the long run.
    Good luck
    Good luck
  • gehejogehejo Member Posts: 5 EDU
    Figured it out on Discord. Nm
