Determine which faces of intersection body were originally open to the air?
 marena_richardson
                    Member Posts: 20 EDU
marena_richardson
                    I have two rectangular blocks positioned perpendicular to each other in an L shape so they overlap. I used opBoolean to get the intersection block. Now I want to know which faces of the intersection block were in the middle of the original two blocks and which two were originally the ends of the two blocks. Is that possible? How would I do that?
If you do want this behavior, you can write some logic which checks for pairs of coincident faces between the original bodies, since
that's the only starting condition that results in "exposed" faces in the intersection. See Jacob's question for how to check if planes are coincident.
