creating a bloc
stephane_dupontstephane_dupont Member Posts: 8
Hi,
I want to create a bloc that is, let's say 100 mm by 150 wide and 120 deep, but at the bottom I have a angle so it does stands with a 45 degres angle and I want to extrude everything inside except 5mm on all the faces
how can I extrude the inside.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 781 PRO
    Not sure what you mean by "extrude the inside." If you mean, leave it hollow, then use the Shell tool and check off "Hollow."
  • stephane_dupontstephane_dupont Member Posts: 8
    Sorry about the wording, I am fairly new, yes I want the bloc empty with a 5 mm wall on all the faces.
    Also, what are the steps I should take to create it.
    ty, I figured it out once I found the shell tool.
