Reason for body draft failure?
alan_lin755alan_lin755 Member Posts: 8
Body draft seems to be a fancy feature, but I never get it work.
Here are 2 examples.
Example 1:
Body part fails to generate unless those 2 surfaces under red lines are excluded.
On the other hand, draft command can finish the same task as expected.
Example 2:
When there is a step, body draft does not work unless I exclude the plane under red line
On the other hand, native draft feature finishes the task correctly
Does anyone know how and why body draft reports errors on these cases?
I am with high interest with this feature but do not know how to use it correctly.
  • S1monS1mon Member Posts: 3,784 PRO
    There's pretty much zero need for body draft here. Body draft is really for much more complex shapes which would normally need a lot of extra work to construct appropriate drafted area. See the examples section of the help here:
    https://cad.onshape.com/help/Content/body-draft.htm
  • alan_lin755alan_lin755 Member Posts: 8
    Hi, thanks for the reply.
    These are my simplified examples to show how body draft fails.
    My actual model is much more complex, bunch of combinations of these 2, and of course body draft fails.
    I read the tutorial before. It demonstrates some successful cases but does not answer to my question.
  • The_M100The_M100 Member Posts: 20 EDU
    Can you attach the link so the forum can help?
    Here is the link, thank you.
    https://cad.onshape.com/documents/e345416b449b0f432f55f7e6/w/b81916c01e6d4a185b3726e0/e/7939b73ffe03527169469678?renderMode=0&uiState=6786123ae2ba1f54a1c41fba
    Hi, I updated the doc to add version tags
    Added tags:
    V1 - Body draft failed on part 1 → I do not know why it reports error on those surfaces
    V2 - Native draft success on part 1 → This is what I expect body draft can do
    V3 - Body draft success on part 1 when faces excluded
    V4 - Body draft failed on part 2 → I do not know why it reports error on those surfaces
    V5 - Native draft success on part 2 → This is what I expect body draft can do
    V6 - Body draft success on part 2 when faces excluded
    Hope someone can help
    Thanks
