Improvements to Onshape - January 10th, 2025
NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
edited January 31 in New in Onshape
Happy new year and welcome back to the latest Onshape update!
CONFIGURATIONS
CONFIGURATION INPUT VISIBILITY
The visibility of individual Configuration inputs can now be controlled based on user selections of previous inputs. This cleans up the user interface, removes redundant inputs, and improves the user experience.
https://onshape.wistia.com/medias/uh8rec8o7z?embedType=async&seo=true&videoFoam=true&videoWidth=1280
DOCUMENTS PAGE
DOCUMENT, FOLDER, AND PROJECT PROPERTIES
The Details panel on the Documents page now includes a Properties panel when a Document, Folder, or Project is selected. Using Categories and Custom properties enables company administrators to add more fields and other information to help manage and track what is related to a Project, Folder, or Document in addition to what it contains.
https://onshape.wistia.com/medias/4airlryxhi?embedType=async&seo=true&videoFoam=true&videoWidth=1280
SHEET METAL
EXPORT HOLE GEOMETRY
The major diameter geometry of counterbore and countersink holes can now be included or excluded from a flat pattern export. Layers in the exported DWG/DXF file separate this geometry based on hole direction (up/down).
https://onshape.wistia.com/medias/hk055bzj1n?embedType=async&seo=true&videoFoam=true&videoWidth=1280
DRAWINGS
CHAMFER TEXT JUSTIFICATION
Justification of Chamfer dimension text can now be controlled by the settings in the Drawing properties or the Styles panel.
FORESHORTENED DIAMETER TEXT
A new grip point on the elbow of a foreshortened diameter dimension enables the text to be flipped to the left or right of the dimension line.
NOTE ORDER
Notes can now be ordered from Top to bottom (default) and Bottom to top to enable notes to be placed at the bottom of a drawing sheet and populate upwards when new notes are added.
SIMULATION
OVERRIDDEN MASS
Parts with assigned materials may have their mass overridden manually to allow for missing details or incorrect material properties. Simulation uses the actual material properties and ignores a mass override, so a new warning indicates that the assembly contains parts whose mass has been overridden. Create a custom material with a density that produces the required mass and assign it to the relevant parts.
«1
  • don_williams909don_williams909 Member Posts: 146 PRO
    I'm betting there's still no way to make countersink holes in curved sheet metal parts…
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 944 ✭✭✭✭✭
    Kudos to export hole geometry!
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • Rhett_RobinsonRhett_Robinson Member Posts: 169 PRO
    The configuration input updates are huge for me! Excited to dig into this more!
  • Lewis_MainaLewis_Maina Member Posts: 12 ✭✭
    This release makes configurations extremely powerful having all possible combinations. What a big update. Thank you Onshape
  • J_FitchJ_Fitch Member Posts: 4 PRO
    Thank you for the sheet metal feature. This is one of many feature updates we have been asking for and it is great to finally see sheet metal getting a bit of love. Keep 'em coming!
  • aeromorrisonaeromorrison Member Posts: 73 PRO
    Great first update of the year! I love the configuration input visibility capability. This will be a big help. I'm also a fan of the Note Order change as bottoms-up notes are really common in many company standards. Additions to document metadata is also really powerful and shows investment into the underpinnings and robustness of the overall product. The Change Log also has 12 items that start with the word "Fixed". It's great to see Onshape staying serious about fixing bugs.
    Excited to see what 2025 holds!
  • christopher_dziubachristopher_dziuba Member Posts: 107 ✭✭✭
    Honestly thought this would come next week!! THANK YOU TEAM.
    I'll be putting configuration visibility rules to good use soon!
  • andrew_kleinertandrew_kleinert Member Posts: 97 PRO
    I've just realized - the change of feature partner on the login screen is synchronized with version updates?
    That's a nice little touch - when going to log in and seeing the model is different, it creates an anticipation to see what has changed with the version! :)
  • randy_hommes295randy_hommes295 Member Posts: 1 PRO
    I noticed in the Documents Page video that Supplier Data was misspelled.
  • EvanReeseEvanReese Member, Mentor Posts: 2,686 PRO
    I'm so pumped about the update to configurations!
  • robert_stilesrobert_stiles Member Posts: 149 PRO
    Yep, this is so great for us… but still we want more power !
    Wait hang on what the hell everything was looking great and then I started excluding config options from properties and my config visibility settings got all messed up!
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,248 image
    @S1mon @robert_stiles @chadstoltzfus Could you be more specific on what you're looking for? We have our own ideas, but are always interested in hearing from customers.
    @christopher_dziuba I'm guessing you're running into the (intentional) restriction that a configuration input (call it x) that is excluded from properties cannot control the visibility of one that is not (call it y). Otherwise, changing x could hide y, setting it to its default value and indirectly affecting the properties.
  • Trina_JamoraTrina_Jamora Member Posts: 2
    Thank you for the updates! They are very helpful.
  • SethFSethF Member Posts: 132 ✭✭✭
    edited January 13
    The configuration update - Absolute game changer. Biggest game changer since Minecraft added the Bundle.
  • nicolas_lagas_Sulzernicolas_lagas_Sulzer Member Posts: 5 PRO
    Wow, the configuration thing with conditions etc is all what I was waiting for! Great stuff
  • Theo_RTheo_R Member Posts: 82 PRO
    Configurations is the start of a series of features we have been waiting for. Awesome!!!
    THANK YOU!
  • Nick_HolzemNick_Holzem Member Posts: 174 PRO
    @ilya_baran I've had a chance to use configuration visibility now, like the others have already said more logic would go a long way.
    Adding and/or options, range setups, or inclusive search/sort would be even more valuable.
    We'd like to set up clearance model assemblies that start from a large pick list. Then sort down based on brand, length, or other attributes and options. Multiple filter options could be chosen to narrow down options or kept broad. Most shopping websites have this sort of filter. Men's or women's, clothing type; tops/bottoms/jackets/base layer/outerwear, size, color etc. Its important it allows multiple selection per category.
    The link Michael Pascoe shares a link to an improvement request with more examples. I'm glad to see this one come to fruition, configuration publisher in SolidWorks was something I had used with in a previous role. It had some shortcomings but was useful. I think Onshape has a chance to knock it out of the park.
    Thank you
  • MK81MK81 Member Posts: 4
    Is there a way to add variable studios to configurations? Or is this feature yet to be implemented
    I want to have different configurations of the variable studio, which affects all parts in the document. Currently, we can only add local variables to a configuration table, which only affects that part.
